help needed.
Old Feb 17, 2005 | 11:36 PM
Fujiz_xb's Avatar
sIcKsCiOnS
Default help needed.
Okay so i was modding the xb.
1. how do you take the cover of the e-brake? i need to put something and need that rubber piece off and if I take it off, will i be able to put the stock part back on?
2. i did a dummy. but i had to cut the o/d button. now i have done work before and i know how impt it is to keep track which wire is wich..however it was cold and it slipped my mind and i cut the wires without labeling them or cut one shorter or longer.. now
how do i determine which wire goes where?
please post only helpfull stuff.
thanks.
Old Feb 18, 2005 | 08:27 AM
CRxB's Avatar
fuji,
it doesn't matter to which wire is which cause its just a momentary push botton O/D. i did the same thing when I replaced my A/T shift **** and relocated my O/D switch to one of the pop outs in onder the cubby on my xB.
here's a pic of my shift ****...
hope this helps,
Old Feb 18, 2005 | 03:03 PM
Fujiz_xb's Avatar
sIcKsCiOnS
yes i go it. ..
___________ --------------
-------------- ______________
^^ i ddint want to do that.
i guess ill just un-solder the connections on the switch.
then ill add more wire to each wire and redirect to another location.
Old Feb 18, 2005 | 03:25 PM
Joehnn's Avatar
Originally Posted by CRxB
fuji,
hope this helps,
I likey that shifter. Great idea about th O/D switch. I have one pop out left and I think I have a use for it now.
Old Feb 18, 2005 | 05:38 PM
Reign_Man's Avatar
thats a sweet shifter, was it hard to install?
Old Feb 18, 2005 | 05:46 PM
superjeer's Avatar
Default Re: help needed.
From memory, I think you can only cut it off. I remember a thread on this ages ago.
Old Feb 18, 2005 | 05:53 PM
Fujiz_xb's Avatar
sIcKsCiOnS
^^^ grr... if the part doesn't fit im stuck. so does anybody know of a e-brake replacement?
SJMiller
Sep 12, 2015 06:33 PM
Wrencher
Jul 29, 2015 03:51 PM
blackpearlTC
Jul 19, 2015 04:55 PM
Krysune
Scion xB 2nd-Gen Wheel & Tire
Jul 11, 2015 09:30 PM
