High Output Alternator's Who's In??????
i have an angle on a high output alternator for the xA/xB
this is double the rated output of the stock unit
180amp vs. 90amp
buying many will be cheaper
breaks down like this
1-5 units $799
6-15 units $749
16-25 units $699
26-50 units $599
not bad at all, if there is enough demand (enough people with money and willing to spend it)
NEED SERIOUS BUYERS ONLY
i can set up a week for ordering, that is the longest window he can leave open for orders to get the discount
after that the alternators will be shipped out first come first serve
there will be a two week build time for the alternators
he will ship individually so shipping will be the only variable in price
talk to JOSH at HOAlternators if you are intersted in this
or keep this post alive, i will give him the link to show our intentions
http://www.highoutputalternator.com/index.htm
180amp vs. 90amp
1-5 units $799
6-15 units $749
16-25 units $699
26-50 units $599
Just some info for the newbies: These alternator rewinds, if done well, will surely supply more power than you can ever use. SERIOUS sp guys can use this and it would work well. Goobers who have a 1000 watt system or lower who think this would be cool to get should know that strapping one of these puppys on will definately be FELT in the power drag on the engine. It takes HP to make this kind of amperage and with the internal stock regulator, when this bad boy is charging, it will be noticable. Just sos ya know.
"Rewinds" rarely work out well in my experience. Th extra heat generated by stuffing more material into the same case negates any increases. You're much better off with a new HO Alternator. I would be leary of any HO alt that was cheaper than $500. When you look at an alternator, the "Hot" rating is more relevant.
these are not "rewinds"
they are custom built
with a warranty, and all their ratings are "hot" ratings
this thing will near double output at any rpm including idle
no headlight dim @ stops is a great thing
we can ask for chrome, maybe....
i was kidding about the chrome part
and the loss of HP is why i bought an intake, header and exhaust
efficiency, baby
efficiency, baby
You are the man!!! Sounds like you know what you're doing. Not that you will notice such a miniscule H-power loss, but it is still nice to ADD a little extra, right? :D
Now, do you need that much power? Your 95 watt alternator can supply approximately 1330 watts of power. So you have your normal load, plus your added sound system. And a 1000 peak amplifier is only capable of supplying about 700 watts rms for very short durations, so it is not using NEAR that much equivalent dc power continuously.
But, as was mentioned by someone else, adding that huge alternator is completely ridiculous unless you are a serious audiophile with a HUGE system. You do not need it. It will not take away any power, but will waste a ton of money. If you want to avoid lights flickering, invest a couple of hundred in a good quality capacitor. The lights flickering are in essence due to a low frequency variation on the power line (sag). The capacitor in effect counters this. Very effective and cheaper than a 700 dollar alternator you do not need. By the cap and save the rest of the money for some other cool mods
you all do realize that everytime one person says one thing someone else says somewhat the opposite then the next person does that same...in a sense everyone is right. caps help so do extra batteries and so do alts. theres no ONE thing you can that will help out a system without needing to upgrade everything else.
you can add a cap but then youll need extra batteries for power but then ull need the alt to support the extra batteries, theres no use in having a huge alt to power large amps cuz then ull need a cap for when the amp cant handle a hughe drain really fast....see its a big circle.
