How can I tell which wire is positive and which is negative?
Is there a way to test out which is which? Is it safe to hook it up and see if it works or will something catastrophic happen if the wires are reversed?
Originally Posted by Big_Jim
your best investment would be a voltage meter!
even if you dont want to spend a ton of money, you can go pick one up from wallyworld or even harbor freight.
Re: How can I tell which wire is positive and which is negat
Now if you are talking about speakers...then the worse thing you could have happen is your signal being out of phase between left/right channels and canceling each other out.
if you looking for voltage what ever you dont buy a cheap test light....
if you use a cheap test light you can do more damage then hooking it up, stick with a meter of some sort.....if speakers or stereo let me know i have wiring diagram for all makes and all years of vehicles.. ALLDATA
Based on the questions you have asked... you just need to take your car somewhere to get whatever you want done ... done. Or at least get someone to help you in person so you can learn. You're going to melt a harness or burn your ECU..
revalina
12
12-27-2022 04:21 AM
XB06
15
10-01-2022 10:24 PM
SpaceCaptain
05-11-2015 06:24 PM
crystaljukebox_com
12-16-2003 08:34 PM
