This is killing me
Old Jan 22, 2007 | 11:49 PM
Iride_xB04's Avatar
Default This is killing me
Ok, I really don't know too much about the Scion xB and it's wiring. All I know how to do is hook up wires and I applied this to my xB when I hooked up my Jensen head unit. Now there are problems with it that i can't fix and every answer I get confuses me more. I bought the radio used and the wired had already been spliced, so I couldn't use a harness. I only get a few radio stations with a clear signal, and almost all the major stations do not come in at all. Also only the front speakers work, the back ones deliver not sound. One time when I was driving the radio froze, I couldn't turn it off or anything I had to pull over and restart the car . Also the video does not work even when I hook it up to the ebrake wire. The only thing this radio is good for is my iPod and CD's.
Can anyone offer me any help or advice? I'm about to throw this thing as far as I can and then run over it with my xB, it's outrageous. Is it a malfunctioning unit? I think I can take it to a Best Buy or a Circuit City to look at it and see what I did wrong in the hook up but I don't want to pay hundreds of $'s.
FYI: I don't have the slightest clue why, but when you put on sunglasses and look at the blue screen thats visible when the screen is closed, there is a black smug or spot on the screen.
Sorry for the complaining or sob story
Any help at all will be so grealty appreciated
Old Jan 23, 2007 | 12:41 AM
TerribleTed's Avatar
Sounds like maybe you have a bum radio. BUT, be sure it is wired correctly. you must have the wiring instructions for the unit. Get them online or from Jensen if need be. You need an adapter plug with labeling. Schosche and other make plugs that plug into the factory harness and give you wires to slice your headunit to. Your radio reception problem is almost certainly that you did not supply power from the remote wire (amp on lead ) of the radio to the factory antenna booster through the scion radio plug. Until it is powered your reception will blow.
Old Jan 23, 2007 | 12:51 AM
SanchezHacker's Avatar
Could you post pics of the wires coming out of the HU, this would help me understand what we are dealing with. also make sure that everything is connected to the proper wire, here is a good guide that shows what does what... http://www.installdr.com/Harnesses/Toyota-Wiring.pdf
On a side note, you might want to just have it professionaly installed. Sometimes it's just not worth the headaches plus if anything goes wrong you'll have a warrenty.
Old Jan 23, 2007 | 01:14 AM
Sciond's Avatar
the guys above gave great advice also I wwould look at the wiring diagrams on here to make sure you what each wire was
Old Jan 23, 2007 | 01:53 AM
Iride_xB04's Avatar
thanks guys tommorow ill bring in the unit and take pictures. i cant thanks you enough
revalina
12
Dec 27, 2022 04:21 AM
Sgtfluffy16
Regional - Northeast
Jul 28, 2021 10:32 PM
Sgtfluffy16
Sep 30, 2015 01:42 PM
Bhikku
Sep 16, 2015 10:57 AM
Atticus_the_XB
Apr 13, 2015 06:46 PM
