?'s for our Stereo system Installers
Here's what I got to work with Alpine Amp 200 RMS at 4 ohms and 350 RMS at 2 ohms. The (ONE) Sub is an Audiobahn 300 (approx. RMS) dual 4ohm.
First question, I would like to know if they are compatible?
Also would like to know how I should wire for best sound quality and so I don't blow the speaker and amp. I would like to wire the amp-speaker so it's 350 RMS at 2 ohms but not sure how to do this.
If you have a link to a diagram that you would suggest, that would help out a lot. Because I know that it's hard to explain this type of stuff to....well people not familier with this type of thing.
Thanks for any help you guys (or girls) can provide.
I am assuming that you have the Alpine MRD-M300. It will be enough to run that sub. When adjusting the gain make sure that you do it with the volume on your radio close to 80% of max volume.
I would suggest a bass ****. It will help out a lot. that way you can have more control of your sub/amp combo. This would be the best one, cause it will work directly with that amp.
http://www.crutchfield.com/S-r7kUjRe...p?i=500RUX4280
Jason
Someone has to know something that can help me out??
Even if you think you know but are not sure, it would help to have another persons opinion.
I am not going to hold anyone responsible if my system doesn't work because of advice given.
I accept full responsiblity.
Hey Jason,
I have a MRPM350.
Do you still think it will be fine?
It's not as powerful (i think) as the mrdm300.
So is it the way I wire the speaker that determines how many ohms the amp will use/have?
Or is it how the wires are connected to the amp?
Hey thanks for your help.
I have a MRPM350.
since your one sub is 4 ohms, it does not matter how you wire it, unless you have 2 subs to bridge down to 2 ohms or a sub that is rated at 2 ohms.
if you want ungodly bass, get another sub and wire it up as follows, connect the speakers, wire spk 1 + to spk 2 -, spk1 neg to neg on amp, spk 2 + to amp pos. this will give you a 2 ohm bridge. the type of bass achieved is mono. stero bridge required 4 speakers at 4 ohms,
6 ohms like JL takes 3 subs to get down to 2 ohm
6 subs to make a 2 ohm stereo bridge.
But to get the best performance out of the sub, build the enclosure the manufactores SPEC. If you want low extention go with a ported box. It will give you +3 dB's.
Yeah that alpine mono block can handle a 2ohm load. We install that amp alot cause of its bang for you buck! And with your DVC Subs you can go either 8 or 2ohms.
Hope this helps!
Hubert
Hope this helps!
Hubert
reagan9000
01-28-2015 06:20 PM
wiltonhall
01-28-2015 03:46 PM
TheRedBox
31
12-02-2003 04:53 PM
