tc navigation head unit
Hey guys, Im interested in getting a navigation for my car. Im looking for a double-din navigation only unit (not interested in DVDs). Are there any manufacturers that make just the navigation plus ability to play mp3s? I know of Eclipse AVNs but 2494 comes with DVD plus navi add on, and the other one (2535?) comes with both. Thanks for your help
This topic has been going on and on and on different threads. Do a search you will find it.
I have given so many info and opinion about it.
See here: https://www.scionlife.com/forums/viewtopic.php?t=64301
Click on Search, type Navigation, select Search for all terms, forum: ICE, Electric and Interior, then Search! You will find a bunch of threads talked about that!
I've had 4 different navigation unit before. I'm currently using the newest Eclipse AVN5435. If you want navi, and no dvd playback, go with Pioneer AVIC-D1.
Originally Posted by zhenya
thanks for your help. It seems like for the price I might as well go with AVN5435 and use the DVD to my advantage
Originally Posted by CyRaX2007
I' don't wanna get slapped for this
but what does DIN or Double DIN mean
i see that in every other post here...
i never found out what it means
DIN is an acronym for the roughly translated "Deutsche Institut fur Normung," a German standards and measurements organization. For our purposes, DIN simply indicates that a device complies with a generally accepted standard of dimension or configuration.
A DIN receiver, for example, is one that will fit in a dash opening having a width of 7.2 inches and a height of 2.11 inches, typically mounting with a rectangular metal bracket (DIN Sleeve) provided with the receiver.
* The DIN sleeve is designed to mount in the radio cavity of the vehicle. It features a flange on the front edge to allow the sleeve to flush-mount in the radio opening.
Some DIN sleeves have a distinct top and bottom - check for "TOP" stamped on the sleeve!
* Once inserted, a series of "V" or "U" notches stamped in the top and bottom of the sleeve can be bent behind the vehicle's trim panel (or installation kit faceplate) with a flat-blade screwdriver or similar tool to secure the sleeve in place. Typically not all notches will be able to be used.
* Following the installation of the sleeve, the receiver slides into the sleeve where it locks in place. This is accomplished by a combination of small clips on both the receiver and sleeve. The location of these clips often vary based on model or manufacturer. It is important that you use your receiver's included DIN sleeve for proper mounting.
* Most manufacturers include specific removal tools to release the receiver from the sleeve. Be certain to keep these tools should removal be necessary.
basically.. civics have a single din
[O___] <kinda like that (example would be a pop up navigation screens like avic-n1)
and scions have double din radios
[O----]
[------] <kinda sorta like that (example would be AVN2454)
[O----]
XB06
15
10-01-2022 10:24 PM
MadSciontist_xB
05-10-2015 06:28 PM
TheSilencerTC
Scion tC 2G ICE & Interior
02-24-2015 04:56 PM
lunchbx05
12-11-2014 06:13 PM
