what size speakers drop into the xB?
Originally Posted by Digicon
i thought the doors were 6.5s and the rears were 5.25
Originally Posted by aireck
this info will help me in my quest to upgrade my sound system....
thank you!!
thank you!!
how do the speakers hit without a box? i have a kenwood MP-7028.
would those tweeter speakers be overkill on the sound?
The front door is two screws and one pop rivet. Then just grab the spot at the bottom of the panel towards the front and pop out towards you. then the panel comes off. Oh yeah also just pop up the window control with a screw driver abefore taking the panel off and you can just pull that through with having to unhook the connector. You are done on the front. I put 6 1/2 in the doors after you remove the rivets I just cut out the speaker and cleaned up the factory baffle and the speaker just screws onto the baffle. Perfect clearance from the window and don't have to spend extra money on a spacer.
The dash can take any 4' speaker just bend 2 of the tabs and put in and you are good to go there.
The back is alot to take out but can be done with time and a little help from a friend as well as a cold beer or two. You need a 8mm allen wrench to remove the panels in the back.
Originally Posted by hotbox05
Originally Posted by firesquare
time to get Funky
now if i can decide finally on a speaker theme. you mind me asking what that set you back?
ts-g1040 4" dash speakers , for 16.50 shipped ( ebay surplus )
over size ( correct ) pioneer 4 way 6.75 ts-a**** 32.00 shipped ( ebay surplus )
and 5.25 2 way pioneer ts-g series 16.00 shipped ( ebay surplus )
All were BRAND NEW but in slightly messed up packaging and missing instructions and speaker wire.
but.... for all 6 interior speakers at less than $$65.00!!!!!!!!!!
I'm running all these off my pioneer deh 7600 deck , and then I have older pioneer 10" impp subs in underseat boxes , powered by a pioneer gm-x862 760 watt amp for the subs.
If you can't tell I LOVE pioneer. my next addition will be either another pio 10 inch sub in the new scosche box , or a custom rear false floor/integrated hidden sub /sub box and a pio 12"
well i got a return check from NY and i spent it on a pair of Type S 4 inch speakers. ad the difference and look is night and day. cant wait to do the doors and rear.
are the front rings hard to get? or who can i go to to get them where they would have them in stock?
"One Ring To Guide Them..."
Sorry.
I made my own templates from mdf . I can send people the paper template for it for 1.00
wait, are you actualy saying all you need to do is drill pilot holes and screw them in?
Sorry.
I'll will be installing my rear speakers and Pioneer Premier 4-channel amp on Sunday 6/12/05. I will take pictures and post here when my upgrade is complete.
Sorry about your experience at Best Buy. The local one near me, the audio install guy drives an tC, so maybe that is why he knew what I was talking about. Plus has worked on a lot of xB's...
Again, sorry (not that I work for Best Buy, but still...you guys went there 'cause I told you that is where I got mine)
OK guys, now for the question that has haunted me.
HOW DO YOU INSTALL SPEAKERS???
i mean the wiring and stuff, is it plug and play, is there soldering involved, do I need to pull wires and strip and splice and dice for it to work. I'm thinking of replacing the front two first, what do I do????
