what size speakers drop into the xB?
Old Jun 10, 2005 | 07:42 PM
  #41
Bull's Avatar
I have some nice Philips Audio 6.5" 3 ways and 5.25" component speakers from an old system that I'd like to use in the xB. What locations would be the best to mount them in? I was thinking of using the 5.25" in the front doors with the tweeter in the factory dash location (replacing the OEM tweeters) and using the 6.5" 3 ways in the rear. Does this sound like a winner?
Also, how much mounting depth is there in the rear?
Old Jun 10, 2005 | 10:51 PM
  #42
marcs_xb's Avatar
Those would probably work fine. You would need to make your own speaker plates for the 5.25" fronts and the tweets for the dash. You could make some for the rear or get the Scosche adapters if the tweets do not stick up past the surface of the speaker. I'm making my own because the Scosche rear adapters are 1" deep and my tweets and mids on my Pioneer Premier 4 ways extend 5/8" past the speaker surface.
There is probably 3" of backspacing in the rear, more depending on the thickness of your mounting bracket.
Old Jun 11, 2005 | 01:43 AM
  #43
hotbox05's Avatar
Originally Posted by rkautz
Originally Posted by hotbox05
I have older pioneer 10" impp subs in underseat boxes ,
Are the boxes actually under your seats or in the back still? I was measuring under the passenger front seat and thought the area was only 9"x9"x___ (something like 3"). I want to do a sub but don't have the money to have a custom box made to replace the floor cubby thing in the back and definitely dont want to loose cargo room.
I have them under the front seats . and my amp is in the cubby in the back.
and there's alot more room under the front seats than 9x9x3 i'll tell u that.
Old Jun 11, 2005 | 06:45 AM
  #44
hotbox05's Avatar
Originally Posted by MacMaster
OK guys, now for the question that has haunted me.
HOW DO YOU INSTALL SPEAKERS???
i mean the wiring and stuff, is it plug and play, is there soldering involved, do I need to pull wires and strip and splice and dice for it to work. I'm thinking of replacing the front two first, what do I do????
You can solder or..... you can crimp on some connectors. i'd say solder just cuz it's more permanent and a better connection. theres a few diagrams floating around here stating which color is positive and which is negative. just search for speaker wiring. colors.
Old Jun 12, 2005 | 02:22 AM
  #45
Sciond's Avatar
Originally Posted by soulcracker
The front door is two screws and one pop rivet. Then just grab the spot at the bottom of the panel towards the front and pop out towards you. then the panel comes off. Oh yeah also just pop up the window control with a screw driver abefore taking the panel off and you can just pull that through with having to unhook the connector. You are done on the front. I put 6 1/2 in the doors after you remove the rivets I just cut out the speaker and cleaned up the factory baffle and the speaker just screws onto the baffle. Perfect clearance from the window and don't have to spend extra money on a spacer.
The dash can take any 4' speaker just bend 2 of the tabs and put in and you are good to go there.
The back is alot to take out but can be done with time and a little help from a friend as well as a cold beer or two. You need a 8mm allen wrench to remove the panels in the back.
yep we found that out......
Old Jun 13, 2005 | 12:30 AM
  #46
hotbox05's Avatar
pics of one of my underseat subs. will add the passenger side later.
this box can be found on ebay for like 75 shipped. the sub is an old pioneer impp 10" single voice coil.
I will add pics of the passenger box shortly
Yes these fit well. the drivers side needs some modification like removal of the jack and what holds the jack in , as well as removing a small tab that holds the seatbelt wiring. nothin 15 minutes and a bit of grinder work couldnt fix.
Old Jun 13, 2005 | 12:31 AM
  #47
hotbox05's Avatar
oh and the passenger side box is cut in a mirror so as to fit . and yeah. any questions pm me.
Old Jun 13, 2005 | 01:41 AM
  #48
Bicepeak's Avatar
Would there be any great improvement in sound if I just replaced the two 4" dash speakers?
Sorry, but I just like easy mods....afraid to do more .
Sean
Old Jun 13, 2005 | 01:43 AM
  #49
hotbox05's Avatar
it does help. it gives you a better high mid.
Old Jun 13, 2005 | 01:46 AM
  #50
Bicepeak's Avatar
Cool! Which would you get for there?
Old Jun 13, 2005 | 02:01 AM
  #51
hotbox05's Avatar
I have the pioneer ts-g1040 two ways. but any good 4 inch should be fine a 2 way will probably be better to catch more highs.
Old Jun 13, 2005 | 02:47 AM
  #52
Bicepeak's Avatar
Thanks! I will have to check into that!
Sean
Old Jun 13, 2005 | 04:11 AM
  #53
Grime's Avatar
Sean
I put some 4" Infinity loudspeakers in the dash, and they totally blow away all the stock speakers. I am missing one front door speaker currently, and the new 4" ers make it sound so much better than stock, its incredible.
Old Jun 13, 2005 | 04:29 AM
  #54
Bicepeak's Avatar
Sean
I will look into those too. Would be nice to have a little fuller sound.
Old Sep 4, 2005 | 05:50 PM
  #55
crazy_kat_matt's Avatar
what size speaker fits in the rear panel with direct bolt up. 4 inch right?
Old Sep 4, 2005 | 07:19 PM
  #56
marcs_xb's Avatar
I don't think any speakers are "direct bolt in" for the xB. 6.5" fit just fine in the back of the xB with a DIY adapter made of MDF or plywood or go to www.cardomain.com and get you some Scosche SASCN656 adapters. You will have to remove the back seat and rear side panels to gain access to the speakers. Here's a link directly to cardomain.com's site: http://www.cardomain.com/item/SCOSASCN656
The Scosche SAT6 adapters are perfect for the front door speakers too.
Old Sep 4, 2005 | 07:23 PM
  #57
i just looked at my car today though, i just saw 2 allen head bolts holding the plastic panel on, nothing about having to remove the backseats to do that
Old Sep 4, 2005 | 09:45 PM
  #58
marcs_xb's Avatar
Those allen screws actually just hold the cargo net or something. You have to remove the back seat to remove the side panels, which snap on once screws, back seat and seat belts are removed. Search here for how-to's on seat removal. I believe there is a sticky on it too.
Old Sep 5, 2005 | 06:02 AM
  #59
ohh shooots.. thanks ill check it out
Old Jan 1, 2006 | 05:05 AM
  #60
Prototype_xB's Avatar
so just to check and make sure understand what's being said. The factory door speakers are 6.75". 5.25" speakers will drop right into the doors, while you'd need spacers to put 6.5" speakers in the doors. The rear speakers are 5.25", but you can fit 6.5" speakers back there by cutting the molding and mounting the speakers on the outside of the grill?
correct?
