Bazooka and aftermarket head units
Old 01-15-2005, 10:03 PM
KevinxB's Avatar
Default Bazooka and aftermarket head units
I am thinking about getting a new head unit. I have the dealer-installed Bazooka sub. I was just wondering how difficult it is to use this sub with an aftermarket head unit. Does the sub plug into the back of the head unit or is it just wired to the rear speakers? If it runs to the head unit will the harness work with another manufacturer besides Pioneer? Any help appreciated.
KevinxB is offline
Old 01-16-2005, 10:40 PM
KevinxB's Avatar
No one with a Bazooka has changed their head unit?
KevinxB is offline
Old 01-17-2005, 06:04 AM
sithscripter's Avatar
The hookup is trivial -- the Bazooka wiring harness is a pass-through that uses the same connectors as the standard Toyota/Scion wiring harness.
The only possible complication is power consumption. The stock head unit draws its power from the accessory circuit and the Bazooka draws power from the dome circuit. If the aftermarket head unit draws power from the dome circuit as well (some do) you may need to run an extra wire for power else risk burning up your wiring harness or blowing a fuse.
sithscripter is offline
Old 01-17-2005, 06:12 AM
KevinxB's Avatar
Thanks for your help. So the bazooka does have some kind of connector that goes to the head unit?
KevinxB is offline
Old 01-18-2005, 07:13 AM
Yes. Search for "bazooka AND harness" and you should find some photos (go way back to the last page).
sehall6h
Scion xD ICE & Interior
02-21-2016 04:28 PM
MadSciontist_xB
05-10-2015 06:28 PM
ej1987
03-23-2015 10:04 AM
TheSilencerTC
Scion tC 2G ICE & Interior
02-24-2015 04:56 PM
wiltonhall
01-28-2015 03:46 PM
Quick Reply: Bazooka and aftermarket head units
