2004 xB Brake Pad Wear Sensor Inner or Outer Side?
Hello all.... I need to know if the front pad's brake wear sensor pad on a 2004 xB installs on the inner side (caliper piston side) or outside facing you....I installed them on the inner side of each wheel....Is that correct?
Reason I ask is the pads were really down to nothing and not squealing; in my haste I forgot to notice how the other previous set was installed.
Thanks in advance...John
Last edited by MR_LUV; 03-02-2018 at 09:46 PM. Reason: Moved to Correct Forum by Moderator
Administrator
Administrator
Hello all.... I need to know if the front pad's brake wear sensor pad on a 2004 xB installs on the inner side (caliper piston side) or outside facing you....I installed them on the inner side of each wheel....Is that correct? Reason I ask is the pads were really down to nothing and not squealing; in my haste I forgot to notice how the other previous set was installed. Thanks in advance...John
MR_LUV
Thanks....I'll check it out when I get a chance. From what I've read, found out, would make sense to put pad sensor on the inner, caliper piston side...if piston got stuck, that side would wear out prematurely and squeal, as opposed to putting on outer side.
brinny37076
11
10-22-2023 11:39 AM
glennscottharris
10-14-2016 04:41 PM
Zensmith
02-03-2011 06:11 PM
George
25
08-31-2004 05:38 PM
