Best brand to go for suspension
ANy idea which one makes the best? TEIN, EIBACH, GOLDLINE etc...
For all parts covering suspension ex. shocks, springs, sway bars, etc.... |
the setup i use is:
trd strut/shocks hotchkis springs hotchkis sway i love the setup its agressive in corners yet quite comfortable on trips for the money i spent i couldn't of found a better deal a couple of guys i know use to following setups stock strut/shock tein s spirngs and stock strut/shock trd springs hotchkis sways |
Sweet any of ur friends tried EIBACH?
Heard its the BOMB...... How about coilovers/dampers? What's the D between them and what are they for? |
Coilovers allow adjustability of height and some allow adjustability of dampering. The shock and spring are designed to work together with the reduced travel. I would decided how much you want to spend ( coilovers cost a lot). Do you need height adjustment or will you always use the same height. When deciding between springs decide how big a drop you want. Goldlines are great, but drop 2 inches. If you want any of these just PM me.
Do u have anything that u can adjust the height of it manually/electronically?Why coilovers are more expensive?
1st set was trd - lower and more confortable than stock, but not too low
current set is rsr - lower than trd, but still confortable. |
Coilovers are the only ones that can be adjusted height wise. It is done manually. They cost more because they are springs and shocks/struts.
Eibach, H & R, and Hotchkis are all great names providing quality products!
thanks for the info. :D
I love my Teins. If you want some springs for a nice stance and for good handling I would go Tein S-techs. I think I might get some TRD struts later on if I can find them for a better price. I also plan to order the Whitelines rear sway bar next week for the rear which should make things much better.
I just scored a set of brand new steel rims which I'm going to put my all season on for winter so I can get some Kuhmos for my alloys in the spring time. |
Re: Best brand to go for suspension
For all parts covering suspension ex. shocks, springs, sway bars, etc.... I am RS*R Springs with the hotchkis sways, JIC Strut bar, and I go on road trips everyother month with the family. No complaints, comfortable ride and never scrap too bad. :D http://www.speakeasy.org/~mdhewitt/T...s/P8142557.jpg The dude on the right is on eibachs. He wanted room for his Chromes and45 series tires. |
well in chicago, potholes are the worst :?
But lucky for me I used the freeway most of the time I want something that'll work just fine with potholes, not to rough of a ride And something that I can adjust when winter comes I know coilovers are the answer (manual adjusting) BUt I haven't seen any coilovers for TC The TEIN's are gud based from the research I did My friend meanwhile have EIBACH spings on his 2000 Prelude Gound control coilovers not sure with his shocks He said it was all gud, he tried few other brands b4 didn't like them I'm leaning more into TEIN then in the future upgrade it to coilovers I already purchased TRD sway bars & Hotchkis front strut bar Do yo know any other strut bar available for TC? |
