DIY brake pad change?
I don't think so. I'm just not strong enough to do it by hand i guess.
Originally Posted by Spiderbox
i didnt use any kind of clamp or anything just popped the new pads in there. should i worry about anything from not using a clamp?
The clamp can't be left in place while installing the caliper with new pads so i assume it's used just to push back the cylinder and not to hold it in place. Is this correct?
Originally Posted by cew_com
Basically, you need to get one side of the c clamp on the back side of the caliper and one on the hollow cylinder looking thing on the inside. You can either catch the edge or go for the center of it, whatever works best for the clamp you are using. Then, just tighten until it is flush with the caliper housing. Once you have everything back together, a few pumps of your brake pedal should get everything adjusted, then it's just a matter of getting the pads properly bedded with the rotors.
FYI, I recently replaced the pad on bot my xA and my girl's with Satisfied Pro VS OEM pads. Very inexpensive($27), quiet, and offer some nice stopping power with the factory rotors.
when i put the new pads in i just pushed the pads in and put the caliper back on double checked after i bolted it back on to see that the pads werent touching the rotor and everything looked ok.
TotalChaos
Apr 7, 2015 09:02 PM
mrsocks
Jan 20, 2015 01:29 PM
kdanie
10
Jan 25, 2004 07:08 PM
