How to Turn Off Traction Control / VCS?
OK, sorry if this is in the wrong forum..
I just wanna know is there a way to turn off traction control AND VCS? I noticed when I turn off Traction Control (via the button)
and take a turn hard.. the VCS light (the car with the sliding deal icon) still pops up. Does that impede the car or control the car?
I'm guessing it might? Can I turn off VCS AND Traction Control completely? Or is Trac Off already doing that?
Thanks all.
______
Thanks all.
______
When you turn traction control off via the dash button, VSC stays on. VSC is not meant to be able to be turned off by the owner/operator of the vehicle. But I do remember a few people on here finding (though accidentally) a way to turn it off. Hopefully one of them will chime in.
Please excuse Hahajoey...he always wanted to be a 'drifter' but he couldn't achieve that status in his previous car, a 2000 Honda CR-V.
He likes to pull his handbrake around corners alot and scare passengers while he does his Takumi Fujiwara imitations around So. Cal...making real drifters run and hide in mountainsides.
first off.. HOW DID SOMEONE MANAGE TO TURN IT OFF?
and 2nd..
DAMNIT JDMXB.. you let the cat outta the bag!!!
i just wanna know how to turn off vcs cuz when the tires
break loose(the crappy tires they are) i can feel someting
hindering it.. like i can feel the car isn't free.. u know?
im NOT drifting it, and i don't take turns super hard. i've just
came to wonder how to turn it off? i think i tried to HOLD down the button..
or like hold it down when u start the engine.. but i dunno how to
tell if VCS is on or off.. there IS an vcs light.. so i duno someone please
help
and ignore jdmxb's commentary lol =X
and 2nd..
help
You can turn it off--but it's not meant to be user accessable.
So you probably will have to get down underneath the car and disconnect something.
Until then--you can continue pulling your handbrake and skidding into driveways.
Originally Posted by Stylis
hahajoey are those work wheels on your avatar? and second- you feel like the VSC holds you back? I don't understand
anyways.. vcs feels like it i dunno like is slowing the car down a little if the tires
are skidding. i just wanna know if theres a fuse.. or a connector..
or like a way to turn it off?
i know that the new m3 has a traction control button. IF U HOLD IT DOWN..
for a while.. it actually takes it into a REAL traction control OFF not just
traction control.. but like VCS or wahtever that car has..
i dunno but anybody's idea's will help! didn't someone dyno their car
at moda car and bbist(steve) or someone like got rid of the VCS problem during
dyno? anyways let me know
I did not really post this (Because driving without it is dangerous) but to turn off the VCS which is connected to the ABS system you have to pull the fuse which is in the engine compartment.
Again it is dangerous but that is how you do it.
oh boy....I can imagine all the boxes laid out on their sides starting with Joey.
i was GOING to do that but i was worried that if
i disconnected that fuse.. the ABS light would show up
and then i wouldn't be able to disable the light(u know like SRS AIRBAGS)..
just wanted to make sure before i try that.. and without VCS.... and abs
or whatever. the car will just be a regular.. NO ANYTHING.. just GO/BRAKE
right? no TCS/VCS none of that stuff.. i just wanna see the difference...
I AM NOT A RACER, IM NOT AN AUTO X'er..
i'll leave that up to stevie bbist..
i just wanted to know. thanks all
When i was installing my TRD Short Shfiter I found a box that held the gyro for the VCS. I'm wondering if it would be possible to unplug it and see what happens. I've been lazy and havent tried it.
Sorry to bump a super old thread. I need to know this information as well. What I do probably isn't considered drifting, but my, pretty much, and I don't use the E brake to do it. It's all in your shifting. The VSC makes it less safe because I have to end up jerking my wheel to maintain control where I should be making smooth transitions into my corners.
Well, your response was to a 19+ year old post...I'm guessing the OP, at a minimum, has figured out how to turn it off by now and, in all likelihood, doesn't need to worry about as I doubt they still own the car.
evolving_machine
Oct 21, 2023 01:16 PM
Atticus_the_XB
Apr 13, 2015 06:46 PM
daniinpitt
Apr 4, 2015 08:07 PM
