Lowering springs and stock shocks...
Thinking of putting some new springs on my 06 Xb. Wondering how much I can drop before I have to start replacing shocks and other stuff. I assume that these will work just fine
Are these too much?
-Tom
Are these too much?
-Tom
Spring choice depends on a few factors, but most specifically on how low you want to drop. The lowest drop available on the 1st gen Scion xB on lowering springs is the Tanabe DF210. This drop can be done on stock struts/shocks as the install does entail cutting the original bumpstops to accommodate, but you will likely want to go ahead and swap out the rear shocks for an aftermarket set for the Toyota Echo. This will give you a nice ride on a decent drop without having to worry about the shock failing.
Scionxa180
16
12-08-2014 04:00 PM
ScionVan
11
12-02-2003 09:37 PM
