Emergency Brake
Old 09-04-2018, 09:14 PM
majikfish's Avatar
Default Emergency Brake
I have a 2006 xB. The rear brake pads are new and adjusted. The emergency brake cable is adjusted as tight as possible and it's still not able to hold the vehicle still when in D or R. It failed inspection.
The cable is connected to the levers on the rear brake system. What else could it be?
______________________________
Last edited by MR_LUV; 09-04-2018 at 10:28 PM. Reason: Moved to Correct Forum by Administrator
majikfish is offline
Old 09-05-2018, 12:53 AM
Super Moderator
SuperMod
MileHightC's Avatar
Might want to check the adjustment of your rear brakes.
From the manual:
MileHightC is offline
Old 09-05-2018, 07:06 AM
majikfish's Avatar
Default Adjust Rear Brakes
Thanks for your reply. I've already adjusted them & followed those emergency brake instructions. Going to have to put it in the shop.
Old 09-05-2018, 03:28 PM
Super Moderator
SuperMod
MileHightC's Avatar
Can you post the resolution to the issue when you find out what it might be? Be nice to have the reference should someone else have the same issue in the future.
Old 09-07-2018, 11:15 AM
2stroked's Avatar
He might have the brake shoes reversed.
2stroked is offline
icestorm
12-01-2017 09:06 PM
fxeditor
06-15-2015 08:56 PM
vitalyze
12
03-06-2009 05:02 PM
Logical
03-02-2008 07:07 PM
ahurdl01
07-19-2004 02:46 AM
Quick Reply: Emergency Brake
