Progress Coils on xA?
I've searched for threads about progress coilovers, almost all of them relate to the xB. Just looking for some input / pics for anyone running these coilovers on the xA. Pros and Cons?
All I know is that it's the cheapest I've seen for coilovers, gives the most drop for the xA.
Bad that it doesn't come with rear shocks but I got Tokico Blues on already so I hope it holds up.
The ride might be too bumpy? Do you feel a lot of the cracks and bumps on the road?
oh so you asked them to change the spring rate to 450lbs? the ride is bumpy because you removed the sway, or because you had to increase the spring rate? higher the spring rate = more stiff and more bumpy? did you ever have the regular set up on your car because i won't be able to compare it to your 450lb spring rate set up.
