Are the rear hubs rebuildable?
Old 09-28-2018, 06:02 PM
jimmyess333's Avatar
Default Are the rear hubs rebuildable?
I know most people change the entire hub assembly to replace a rear wheel bearing but can the hub be disassembled and just the bearing replaced?
I have a press.
jimmyess333 is offline
Old 09-28-2018, 07:09 PM
Moderator
Moderator
A quick search on Rockauto shows there is no standalone bearing offered for the rear hubs and if they don't have it I doubt you're going to find it. Besides, a new rear hub gets you not only the bearing but the ABS sensor also and replacing a rear bearing, even with access to a press, seems like far more hassle than it's worth.
Spring for the hubs...
MileHightC is offline
Old 09-28-2018, 11:08 PM
jct
jct's Avatar
they are rebuildable, idk how they do it... it's much easier to replace the whole assembly. esp when it's only 4 bolts knock it out, pop a new one in
jct is offline
Old 09-28-2018, 11:28 PM
Thanks for the replies guys.
MilehighTc I don't find this kind of work much trouble at all as long as I can get the parts and there are no surprises. I should already have the tools needed and if it saves me $50-$100 it's well worth it to me.
But If I can't get the right size bearing then I'll have no choice but to buy the complete assembly.
I'll let you guys know what happens.
I plan to work on the car Oct 6th so you won't hear anything before then unless I get new information first.
Old 10-07-2018, 06:26 PM
Default Took it apart. Not rebuildable
I pried the back cover off
And pried out the cage
It turns out the hub is stamped like a huge rivet. No bolt. The hub has to be destroyed to get it out of the bearing. The only thing salvageable is the outer housing and I have not found the new inner hub or bearing for sale.
So I picked up a whole unit from the junk yard for $15 from an xB and it went right on. I have not found ANY xA Scions in the junk yards. It must be a rare car.
Old 10-07-2018, 07:30 PM
Moderator
Moderator
Glad you gave it a try but that would confirm why I wasn't able able to find any separate bearings online...I found components for the ABS portion but obviously that's about as far as you're going to get into the rear hub with that 'riveted' portion.
Good info for future reference.
Murphys_Law
08-18-2010 11:55 AM
JohnsonXa
02-21-2005 10:17 AM
jocappy
08-30-2004 01:11 AM
XBman
12
05-20-2004 06:18 PM
DoNuT
12-30-2003 07:49 AM
Quick Reply: Are the rear hubs rebuildable?
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
