suspension
what would I need to do a full suspension on a 05 xb? What are th best brands and about how much am I looking to end up spending? any help would be greatly appreciated :eyebrow:
Do you want coilovers or a spring + shock set up? The price would be something like $400-$1k+. As for tools, that part I dont know. I would know you would need a torque wrench or two. For a coilover kit, just pick the brand & buy. For a spring & shock there is some to pick from. TRD or Koni Shocls. Tanabe, Gold Line, H&R, RS*R, Tien, Hotchkis, & some others make springs for the xB. It would depend on what kind of drop you want.
like an inch and a half to two inches , i want a good ride quality
Goldline, Tein, Hotchkis are good. Expect to pay about $150 and install them yourself. Do some looking around here for reviews of them. Lots of people are saying the Koni shocks are necessary when lowered.
Personally, I have Hotchkis and stock shocks, which are soon to be replaced by the Konis. Look around the Corner Carvers forum for more info: https://www.scionlife.com/forums/viewforum.php?f=7 |
bags go with strut bags from universal air suspension company.. and firestone 2600 bags for back with a 5 gallon tank...
about 1300 hundred in total.. probably the 1500 but nice ride looks good.....too |
You could always go TRD but for the drop you're looking for I say Hotchkis. The hotchkis spring make the box look like it's right on top of the wheels. One of our local customers took me for a ride in his box with the Hotchkis springs and they still ride great. As far as shocks go TRD's will do the job just fine. If you really want to go ALL out you could get the hotchkis sways and a strut bar.
Hotchkis springs http://www.trdsparks.com/displaypart...1&parts_id=477 TRD shocks http://www.trdsparks.com/displaypart...1&parts_id=312 Hotchkis sways http://www.trdsparks.com/displaypart...1&parts_id=478 Strut bar http://www.trdsparks.com/displaypart...1&parts_id=356 |
Moved to CC... :lalala:
eibach...little pricy but looks great!!!
mmmmmm bags. :come:
Originally Posted by vicdeng
Just a question. i am thinking to get some sway bars for my xB. and the Hotchkis makes the front bar 28mm, and the rear about 12mm. But Progress makes the rear 22. Does that difference make a different ride quality? And also for some coilover and spring rate, some companies make the front stiffer than the rear, and some did exactly the opposite way. Does that also affect the ride quality? Can someone acknowledable to answer my question? Thank you
The Progressive rear sway is about 10 times stiffer than the Hotchkis. You can really feel the impact on oversteer and handling. Because of this, you can also feel the negative impact on the ride. The rear sway "stiffens" the rear suspension when there is differential movement between the wheels (side to side). When you hit a bump on one side of the car, the rear sway will transmit some of that force to the other side of the car. The car sort of waggles side to side a little. But, IMHO, the handling benefit is more substantial than the loss in ride comfort. Full recommendation for the Progressive sway. |
Originally Posted by jomo
The Hotchkis sway bars probably won't have much effect on the ride. This is because they are a very mild improvement in handling. The hollow front sway may be a bit different stiffness than stock (lighter? yes....stiffer? unknown....). The add-on rear sway hardly adds any stiffness. To me, this sway bar set is pretty darn lame. I would love to hear the reasoning for this super wimpy, 1/2" rear sway. The Progressive rear sway is about 10 times stiffer than the Hotchkis. You can really feel the impact on oversteer and handling. Because of this, you can also feel the negative impact on the ride. The rear sway "stiffens" the rear suspension when there is differential movement between the wheels (side to side). When you hit a bump on one side of the car, the rear sway will transmit some of that force to the other side of the car. The car sort of waggles side to side a little. But, IMHO, the handling benefit is more substantial than the loss in ride comfort. Full recommendation for the Progressive sway. |
