TANABE or Megan springs?
which of the two is a better spring? any pics of either on an XA?
As a distributer of tanabe, I can honestly say tanabe is much better, I just ordered a set for my box.
If you want comfort and more of a drop then go with tanabe DF210's.
If you want stiffer springs and spend less money... go with megan racing springs. |
TANABE ftw
that is a obvious question...brand name vs junk? I'd take Tanabe without a doubt
megan springs arent junk it all depends on what your looking for i perfer the megan springs cuz of the spring rate i like hitting the corners hard and the stiffer spring rate helps alot the ride is a little rough but i dont mind and with the higher spring rate your less likely to bottom out its all about what you want the way i see it megan springs are built with performance in mind not comfort tanabes are more of a blend of comfort and mild performance |
oh come on... :)
