Turning off Slip Indicator Warning Beep? Know How
I have two solutions. The cheap way is to remove the fuse, or another component. Myself I disable the Yaw Rate sensor under the center console next to the shifter, that disables the ABS, Trac, and VSC, Just be careful you wil not have anything to save your @$$ if you make a mistake. The other solution is to get some really sticky tires like Falken Azenis RT-615, Toyo RA-1, or any other sticky tire.
why not just cut the wires in the fuse block for it and wire in a switch, so for the most part it will be on but when you want to disable it just flip the switch, then you can have the best of both worlds, thats what i plan on doing with mine
my slip indicator light comes on and it goes beep beep and my car shudders shakes and brakes
took it to my mechanic for a diagnostic check the problem was my steering angle sensor
Slip control light came on after new tires today
Hello SL forum! I haven't been here in so long
This afternoon on the way back from another town I had a tire blow out on me, had them replaced and on the way home I took an on ramp pretty quickly and the Slip light barked.
I felt the car brake and try to stop what it thought was a skid. Is there a reset I don't know about when new tires are put on? I looked around and didn't see anything obvious in the forums so I thought I would ask.
05 xB
05 xB
stillcole
Scion tC 2G ICE & Interior
06-14-2015 09:19 PM
Green_rino
Scion FR-S ICE & Interior
01-20-2015 01:41 AM
cid_mcdp
01-05-2015 02:45 PM
