2006' Scion xB 170k, 5speed .
No CEL , or Fault Codes. Just the VSC, ABS and Traction Control Off is illuminated.
I do believe a tie-rod is going out on my passenger side .
A Jeep compass had same issue , new upper and lower control aims were changed and an alignment was done. That had fixed the VSC Traction Off lights issue in that case.
I was also reading it may be the angel sensor / clockspring , if so how should I go about test/reset ?
Ideas?
Installing "new upper and lower control arms and getting an alignment done" will not solve (or trigger) warning lights on the dash of any vehicle. Nor will a Tie Rod End wearing out. Those are purely mechanical suspension components and adjustments. A proper code reader will tell you what's going on with your xB. I do not recommend throwing new parts at the problem until you fully understand the cause(s).
