05 Scion xB Rims and Tires
I want to use 16" rims. What is the correct specs and What size tires? Car is stock height. Would 16x7 offset +42 bolt circle 5x100/114.3 fit?
If so, what's recommended tire size. Want absolutely no rubbing. |
According to the Chart above, the Recommended Size for 16" is a 16x6 Rim +39 and a 185/55R16 Tire IF you don't want it to rub. Or you can go with a 16x6.5 +35 and a 195/50R16 Tire if you wish. No, your 6x7 offset +42 bolt circle 5x100 won't fit. The Bolt circle pattern is 4x100, not 5x100. MR_LUV |
Originally Posted by NewYoRicanPapi
(Post 4285558)
If so, what's recommended tire size. Want absolutely no rubbing. I run 16" aftermarket wheels on my 2006 xB in the summer with fairly meaty tires and I have 1.5" lowering springs. I'll run down in the basement later and see exactly what size they are before reporting back later. |
Ok, went down and checked what the details are on the 16" wheels I run on my 2006 xB. The tires are 205/50-16 and the wheels are 16"x7" with a +40 offset. And no, I don't get any rubbing.
Here's a link to a handy site that allows you to play with size, offset, etc. https://www.wheel-size.com/calc/?whe...cl=50mm&sr=0mm |
Originally Posted by 2stroked
(Post 4285568)
The big issue with the wheels you show there is the bolt pattern / circle. A first gen xB has a 4x100 bolt circle. So you can write them off immediately.
(Post 4285568)
Originally Posted by MR_LUV
(Post 4285565)
https://farm1.staticflickr.com/785/4...5fc61178_c.jpg
(Post 4285672)
whats the streets like where you live ? out my way bumpy roads not too bad some potholes not too bad. does that tire size feel a good ride ?
