Wheels and tire combinations...
Click Here
215-55/16 fit on Xb??
Old 07-29-2004, 10:15 PM
Default 215-55/16 fit on Xb??
Does anyone know if these tire will fit with stock springs I can't lower mine because I live on a gravel road that has 6" deep holes in the spring.Wanted to go a little wider than the recommended 205's.
scionjim is offline
Old 07-31-2004, 08:06 AM
MyBoX's Avatar
What size wheels are going to mount them on ?? Sean
MyBoX is offline
Old 07-31-2004, 03:38 PM
Old_Punk's Avatar
By "size" you mean width, offset, etc., right?
But let's look at relative tire dimensions first, because a 205 and a 215 would probably both fit the same 7"-7.5" wheels, since there's only a 1/4" difference in tire width.
Stock xB tire size is 185/60-15, which means the tire is 185 mm wide and the sidewall is 60% of the tire width (in this case, about 4.4 inches from the inside of the bead to the road). This tire is 23.7" tall. And, of course, it fits on a 15" wheel which I'm guessing is about 6.5 inches wide.
In comparison, a 215/55-16 tire is a quarter inch wider and 1.6" taller (25.3"). The sidewall is 4.7". Since it's taller and wider, there might be clearance problems where the tires rub against suspension parts when turned all the way left or right, particularly over bumps. But maybe not. There seems to be plenty of fender well room for up and down clearance, unless you've done a drop. Meanwhile, your speedo will read 6.6% slow unless you recalibrate the car's computer. Watch for cops.
The optional tire sizes recommended by Scion, Tire Rack and others, are:
205/50-16 (24.1" tall)
205/45-17 (24.3" tall)
215/35-18 (23.9" tall)
All of these are shorter than the 215/55-16 and the 18s are only 0.2" taller than the stock 15s.
The question is, why that particular size? Do you want wider tires or the look of thicker sidewalls, or more comfort or all of the above? Because if you just want wider, 215/50-16 or 215/45-16 would certainly fit.
Old_Punk is offline
Old 08-30-2004, 06:09 AM
215/55-16 are probably too tall and would probably cause all sort of rubbing problems. I have 215/50-16 (on a 16 x 7.5 rim) and have a slight problem with rubbing (they catch slightly on the plastic wheel well when I turn in reverse). Try to stay within 3% of the stock diameter. The size you asked about are over 6% larger than stock. Also suggest you buy some gravel and fill in some of those holes.
softrider is offline
Old 08-30-2004, 06:32 AM
jjambox's Avatar
215/55/16 on goldlines
jjambox is offline
SpaceCaptain
05-11-2015 06:24 PM
KTamAK187
04-15-2015 10:08 PM
HotLavaDestiny
04-10-2015 05:10 PM
skruff
04-06-2015 06:34 PM
Quick Reply: 215-55/16 fit on Xb??
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
