DIY-Installing Longer Wheel Studs..
Old 08-07-2008, 01:39 AM
Wagonistas
Just1n's Avatar
used this today ..thx
Just1n is offline
Old 08-23-2008, 10:14 PM
biancoxb's Avatar
Lookin into the 10mm just for the rear , just wondering if anyone had some before and after shots with the stock steelies and is it a simple put it over the studs and bolt the wheel back up mod or is there a little more to it ? I always thought the rear tires were just too unusually spaced together
biancoxb is offline
Old 11-03-2008, 04:45 AM
AzNpImP67O's Avatar
good job on the DIY
AzNpImP67O is offline
Old 11-03-2008, 04:57 AM
dexter_5000's Avatar
does anyone know the full specs of the stock studs? i need the knurl and thread size of the factory stud.
dexter_5000 is offline
Old 02-14-2009, 06:10 PM
gkccbc00's Avatar
how did you manage to break the 17mm bolt free?
gkccbc00 is offline
Old 02-16-2009, 08:10 PM
Improbcat's Avatar
Good writeup except for one thing:
You will probably want to use a torque wrench to get the leverage you need to wedge the new stud all the way in so that it is flush like the stock stud used to fit.
Don't EVER EVER use a torque wrench like a breaker bar to get greater leverage. A torque wrench is a delicate & precision calibrated tool and after being used like this it may no longer give a correct torque reading, which could be very dangerous (imaging thinking your lug nuts are torque tight enough when they aren't).
If you need extra leverage go and buy a cheap breaker bar, it is well worth spending the $10-$30 on one to save your $50-300 torque wrench.
Improbcat is offline
Old 02-18-2009, 03:41 AM
SKIN's Avatar
X2
You might as well throw your torque wrench away after this suggestion.
SKIN is offline
Old 03-11-2009, 03:20 PM
I can confirm that ARP Evo extended studs fit the xA.
__________
Old 09-22-2009, 02:01 AM
willfong's Avatar
Originally Posted by dexter_5000
i can confirm that arp evo extended studs fit the xa.
Hi Dexter and everyone,
So the ARP Mitsu Evo extended studs work on the xA? I assume it will be the same for a 04-06 xB?
How much longer is the threaded length compared to stock in the rear and front studs?
Why did you go with the ARP Mitsu Evo extended studs instead of the ARP Honda extended studs - as I believe the Honda and Evo have the same thread - 12mm x 1.5?
I ask because I need to replace my stock studs on my 2005 xB as the Volk wheels I have allow me to only thread on my lug nuts about 5 turns when tightened in the rear.
In addition I would like to install some 5mm or 10mm spacers to rear in order bring out the wheels a bit more flush with the rear wheel well.
Would any of these work for as extended replacements for the rear and front wheel studs..
http://www.hrsprings.com/applications/studs
Thanks in advance for the info!
Will
____
willfong is offline
Old 09-22-2009, 05:52 AM
went with the evo studs cause the knurl diameter is the same not sure how much longer than stock these are. someone else did fit them on the rear i haven't gotten that far yet though.
Old 12-23-2009, 06:22 PM
D-Boy's Avatar
I was wondering would this be the same steps on a tC?
Thanks for DIY.
_________
D-Boy is offline
Old 05-13-2010, 09:07 PM
Wagonistas
Just1n's Avatar
In 2008^
and again today due to one snapping off..
Just1n is offline
Old 11-29-2010, 11:41 PM
JTerry368's Avatar
Anybody have a more in-depth walkthrough (with pics) on how to remove the studs in the rear drum brakes?
JTerry368 is offline
Old 12-01-2010, 02:37 AM
in order to install longer studs in the rear you'll have to remove the rear hub assembly completely. just not enough room to put the longer studs back there with it installed. i tried a few times and just ended up replacing them with stock ones.
if you just need to change them. have to pop off the drum. the studs themselves will just hammer out. then to install the new one you need to use an over sized nut as a spacer and a lug nut threaded on the stud tighten the lug nut will suck in the stud.
Old 07-27-2012, 12:00 AM
joeyscion's Avatar
Nice write up
joeyscion is offline
Old 02-03-2018, 10:04 PM
Administrator
Administrator
MR_LUV's Avatar
Thumbs up
MR_LUV is offline
Sgtfluffy16
Regional - Northeast
07-28-2021 10:32 PM
airmankevin1
11-17-2015 05:44 AM
SoKrispy
Scion tC 2G Aero & Exterior
10-13-2015 03:48 PM
Sgtfluffy16
09-30-2015 01:42 PM
Andreas24
09-15-2015 02:10 PM
Quick Reply: DIY-Installing Longer Wheel Studs..
