need help with tire size!!!
I didn't see my size covered in the fitment section
I have a set of GT20's (fake Equip) 16x7.5 et38 going on 06 xB ,,I'm going to lowered it a little bit for the nopishow ,but this is my wifes DD thanks in advance guys ,,,,,ohh yeah what are you guys doing about the front rim rubbung the brake caliper ,,I thought about grinding the back side of the wheel I'm counting on you guys to point me in the right direction https://i50.photobucket.com/albums/f...e/MVC-353F.jpg https://i50.photobucket.com/albums/f...e/MVC-352F.jpg you guys like the color???going on white xB |
help...please!!!
I know one of you have put these on your xB...help me out!!!
dont grind
don't grind the wheel you may throw it off balance or weaken its integrity
some have ground the caliber or you could use a small spacer say 5mm in front. nice color are those drag's wheels haven't heard of them before. |
yep they are DRAGs ....anyone on the TIRE SIZE?????
I searched around and most tire distributers say you 215-40-16...but they cost to much....any ideas on a cheaper size???
ttt....c'mon help me out
id go with like a 205 or 215 for width and a 45 or 50 for side wall
I just went with a 205/50/16 on my 16x8 rims..no problems in the front, but on the rear I had to do a little mod to the trailing arm..just a bit of trimming or if I had some 5 or 10 mm shims everything would would have been fine.
you think if i went with 205-50-16 on 7½'s i'd have that trailing arm problem???
and also is 205-50-16 apprx the same hieth is the oem tires ,i dont wanna mess up the speedo to much? Thanks |
215/45/16 -- 1/2% faster (smaller dia) closest to stock
205/45/16-- 2 1/2% faster """ ''''' if you go bigger than stock diameter 205/50/16 your speedo will be off even more than it is from dealer @3mph a faster tire (smaller dia) will help correct this and give more clearance when lowered this calculator is pretty helpful. http://www.1010tires.com/TireSizeCalculator.asp |
you shouldnt have any rubbing on the back at all my 17x8 +40 barely rubbed yours are lower offset and not as wide = more clearance
Stick with 205/50/16's and you will be fine. Have fun at NOPI. I did it 3 years ago with my toaster and had a blast. Looking forward to doing it again next year.
yeah guy I got a buddy that work at Maxxis Tires ,,,and I might paint my orange wheels and get free tire....I'll give it a try anyways
but yeah i'm going to get the 205-60-16 |
on the wheels you should have left the lip chrome
http://www.rims-n-tires.com/rt_specs.jsp?postId=906 |
dude...your totally right ,I mis-typed or I'm dyslexic...either way
I AM GOING WITH 205-50-16 thanks guys!!!! |
no problem :silly:
Please post up pics of the finished product. |
