Scionlife.com
Scionlife.com (https://www.scionlife.com/forums/)
-   Scion xA/xB 1st-Gen Wheel & Tire (https://www.scionlife.com/forums/scion-xa-xb-1st-gen-wheel-tire-1608/)
-   -   Tallest Tire size on xA with Stock Suspension? (https://www.scionlife.com/forums/scion-xa-xb-1st-gen-wheel-tire-1608/tallest-tire-size-xa-stock-suspension-239556/)
TheEndonEmpty May 14, 2021 04:20 PM
Hi All:
I'm new to the forum. I have 2006 Scion xA with around 70,000 miles on it.
I have a question that I was hoping someone might be able to help me with: What is the tallest tire height that I can put on this car without issue?
I was hoping to be able to fit 195/65/15's which are 25" in overall tire height compared to the stock tires at 185/60/15 which are 23.7 inches in overall tire diameter. I think this means that I'll have an increase of 1/2 of that diameter in height under the wheel well and an increase in 1/2 of that diameter in overall ride height (hitting the road). So, it should raise the car by 0.65" in overall ride height and add 0.65" under the wheel well. Does 0.65" under the wheel well leave enough clearance there? Is there an even taller tire I could go with?
I like the look of more rubber and a taller ride height. That's all I'm trying to accomplish. Nothing significant.
Thanks so much for your help.
Sticky How To Advanced Search SL (Scion Life)
______________________________
MR_LUV May 14, 2021 04:43 PM
Start with:
Sticky xB 1G, xA Wheel, Tire and Offset Calculator
MR LUV
__________________
TheEndonEmpty May 14, 2021 07:49 PM
Originally Posted by MR_LUV (Post 4307064)
Start with:
MR LUV
__________________
Thanks for the guidance. I'll start there.
Apologies to admins for posting question in wrong forum/thread to start.
MR_LUV May 15, 2021 07:04 AM
https://cimg9.ibsrv.net/gimg/www.sci...867e0b5283.jpg
Use this Rim and Tire Size Calculator
Experiment with the Different Tall Tires Sizes. See how changing your tire size affect's your car's performance.
MR LUV
__________________
© 2026 MH Sub I, LLC dba Internet Brands
