Suspension: H&R 1.5" drop springs on Koni STR shocks and struts with about 2 degrees of camber in the front; rear is at factory setting.
Wheels: 16x8 ET25 front and 16x9 ET15 rear with no spacers. Light roll on the rear fenders and the only (very slight) rub is at the inside front at full lock.
Tires: Trash that's getting replaced soon. They're currently 205/50R16 all around, and I'll be changing the front to 195/50R16 when they're swapped. It will bring the overall diameter almost exactly to stock and I'm hoping will correct the rubbing.
The wheels were a used find that I'm not sure I'll be keeping yet. I love the way they look on the car, but they weigh a ton and the brand isn't exactly highly regarded in performance circles. I'm going for weight reduction with this project, so this choice was admittedly a bit counterintuitive. Whatever. I'm also doing a whole lot of research into how I might be able to bring the roll center and scrub radius back to a more functional level. The car handles decently well as it sits, but it can definitely be better. I also have poly bushings for the whole shebang that are just waiting for a weekend where I'm less busy and/or lazy and can install them.
When I got my '06 in cold cold Minnesota February, it had 14" steelies on it, with 10 year old tires. Had to get tires right away.
As weather warmed, I began looking for cheaper 14" wheels that looked good, to which I could remount my brand new tires. These are from a 2001 Corolla. $100.
Keeping it in the family, anyway.
Reason: Awarded 5 Yr Badge
Nothing at all wrong with those wheels and no one would ever guess they are 'only' $100 wheels.
Those look fantastic. I really dig how the angles of the spokes compliment the shape of the head and tail lights from the side. That's a mighty fine score for $100.
Those look great! My wife and I each have xA’s and I figured maybe I should look for snow tires since I now had an extra set of steelies after getting the Corolla wheels.
I found a set of Michelin X Ice made in late 2019 ( so very low miles... just over one winter) that a guy used on his Miata. Mounted on new steelies same center bore and offset as our Scions.
Rims and tires for $175. Probably put them on my wife’s car next winter. Still have empty set of steelies, so maybe I’ll just keep looking for another bargain!
We just bought house in Mesa, AZ, so won't be needing any snow tyres soon. ;) But would like to get something to replace factory steelies on white car. Leaning towards 16x8" Enkei RPF1s as the they have proper 38mm offset. Will let me run 215/45-16 tyres without needing excessive camber to avoid rubbing. I don't like feel of street cars with too much camber, makes steering vague without feedback (also reduces braking-grip). Change in scrub-radius from pushing wheels outwards also causes darting and hunting front-end when hitting bumps.
Seriously...those are the best looking wheels I've ever seen on an xB!!! Very unique and stylish. I'm currently looking for a set!!
These are the cheaper of the options of companies that make this style (Crimson is still pricey, I just got lucky. And these are flow formed one piece. There is another one piece version but I forgot who makes them.)
The other two companies I know for sure that make this style are AME (Crown Jewel), and SSR (They make the three piece version and are pricey). Like I said, I got my set for a steel because the kid didn’t really know what he had.
People will usually try to compare prices of our JDM wheels to what they find on Croooober or UpGarage, but never figure in the cost of shipping and import fees. Buying off Croooober or UpGarage isn’t worth it unless you are sharing a shipping container with someone. So if you find a set of $300 JDM wheel on UpGarage or Croooober, be prepared to spend another $600 just in shipping costs. This doesn’t figure in tax or import fees. That $300 set of wheels just became an$1200-1500 set of used wheels.
I decided to switch things up a bit in a more conservative direction (apologies for the poor camera focus).
The wheels are Konig 15x7 ET35 wrapped in Kumho 205/55R15 tires. The improvement in handling and ride quality over the 16s I had on her previously is remarkable. I think the weight was the biggest factor - the 16s clock in at nearly 20lbs each while these are about half that. Add in the weight of the tires and that's a huuuge difference on a subcompact with dinky suspension components.
I'm glad you're happy with the improved ride and handling. In the past, I'd tried 17's and didn't care for the ride although the increased handling was pretty awesome. I'm currently running 16's and find them to be a pretty good compromise. Remember, tire choice alone can make a huge difference in ride and handling - even in a 15" tire.
As for the wheel choice, that's exactly why I don't like black wheels. You can spend all the money you want on a great pattern with intricate machining and the black finish makes it all but invisible. At least they look dirty all the time. But the great thing about this country is that everybody has the right to their own opinion. Enjoy!
Thanks. IMO, 16 is aesthetically about the perfect wheel size for our cars. I really wanted to make them work, but those cast wheels were absolute boat anchors. The best analogy I can think of is tying sandbags to a cat's feet.
I'm normally of the same mindset, but these actually look a lot better in proper lighting. That pic was taken right before the sky completely opened up. My long term plan is to have the box resprayed in Toyota Cement Gray. It's that weird industrial gray that's been popping up on new cars in the past few years, and I think it'll be a nice contrast against the gloss black wheels.
Too much unsprung weight will do that. Totally screws up both ride and handling. Imagine what a 99 Crown Vic with 28's rides and handles like.
Yeah, I think 16 is just about right size. I'm looking at Enkei RPF1 in 16x8" +38 next. They weigh 15.6-lbs each, which is about 4-lbs less than stock steelies and couple pounds less than current my MR2 wheels. Those did have noticeable ride-quality and handling improvement compared to stock, even with just 2-lbs savings. Looking forward to shaving another 2-lbs per corner and getting that much improvement again!
There was teaser vapourware at show that never made it to market. Volk TE-37s made from titanium! Weighed about 7-lbs each... droool... Probably would've cost fortune!!! Now we've got CF wheels starting to appear... although it appears they're still heavier than magnesium ones. Had set of those on my track car and was simply amazing...
