Miata Wheels
well check the offset, hub sizes, and bolt pattern, if the miata hub size is bigger or the same to your scion, then it'll work as long as the offset clears the caliper, and the bolt pattern is the same...
Everythihng else will fit, but like already stated, your front calipers would probably crash against the spokes. When I had some 15x6.5 +38 Rota Grids on my box, the spokes just barely cleared the calipers. I'm talking about 1 to 2 mm of clearance. They were that close.
Yes, in fact, all 1990-2005 Miata wheels will fit. The center hub opening is 54.1mm, exactly matches the Scion too. There are lots of Miata wheels on the used market, so this is a relatively cheap mod that eliminates those dorky plastic wheelcovers.
We are running 2002 Miata 15" alloys on our 2005 xB. It drives and handles great.
evolving_machine
10-21-2023 01:16 PM
