ABS Dynamics Grill fitment..
Greetings! So I just got an ABS Dynamics grill with halo fog lamps and ran into a problem. Apparently in 06 Toyota moved the crash sensors to behind the grill and the new grill no longer direct bolts.
Does anyone know where the old location for the crash sensors is/ has pictures. I have the grill on with a little trimming to the fog light housing but the lamps cannot fit.
Any help would be great!
____________
____________
Have you checked any of the parts diagrams on some of the online OEM parts vendors...it won't be as good as a picture but it may give you a general idea of where they were compared to where yours are now.
LH looks to be under the air intake tube mounted to the 'rail' and RH looks to be right in front of the alternator.
Thanks!! tells me all i need to know. Unfortunately looks like the sensors have changed as well as mount orientation, so the plan is a no go. Looks like ill have to move them to a different location keeping orientation and lateral placement since horizontal and vertical should have little to no effect on deployment timing. Thanks again for the info. ill have to put up pics of before and after move.
Kingshawty12
03-04-2013 06:36 AM
