Alarm and door locks not working.
i recently had my battery die so I had to jump the car. After that happened I had to replace the throttle fuse to get that to work again. Then the alarm and door locks won’t work. I have to turn the car on to open the door locks. I’m pretty sure it’s a fuse somewhere but I don’t know which fuse to replace for the alarm/door locks system. |
Did you try searching the forums for similar posts? I can't recall specifically but I thought I remembered stumbling across a post where someone had the same issue and detailed what fuse it was.
I'll take a peek in the next day or two and see what I can find in the service manuals if you don't have any luck finding it. |
Found the problem
It was the fuse for the gauges. The 1st 10 amp fuse at the top, controls the alarm gauges and the door locks. Yeeeyaaahhh!! |
Originally Posted by Jtbones1
(Post 4287389)
itnwas the fuse for the gauges the 1st 10 amp fuse at the top controls a the alarm gauges and the door locks. Yeeeyaaahhh!! |
