Blown Halo LED's and voltage questions
I have a set of dual halo headlights that you can see in my pics.
I blew the LED's in the halos.....took it apart and found out they are little flat ones...anyone know what I mean? Also...I noticed that there are no resistors in any of the lines going to the LED's...I've only had experience with LED's running with a resistor coming off of a 5volt source. These are off of a 12 volt source no? Thanks for any info you guys give, -Brian! |
Re: Blown Halo LED's and voltage questions
I blew the LED's in the halos.....took it apart and found out they are little flat ones...anyone know what I mean? Also...I noticed that there are no resistors in any of the lines going to the LED's...I've only had experience with LED's running with a resistor coming off of a 5volt source. These are off of a 12 volt source no? Thanks for any info you guys give, -Brian! norris_l_duckett hope this helps! |
