Did I Get The Wrong Reverse LED Lights?
OK, I just want to know if I gotthe wrong LEDs. I have a 06 xB and I wanted to upgrade the stock bulbs for the reverse lights to something brighter. My back window is tinted and I have trouble seeing at night when I'm backing up.
I ordered a set or Pure white LEDs from Garage 1217 and the connector didnt seem to fit well. I had to bend the leads in the socket to get the LED to fit and it still was loose. Also, it wasn't as bright as I thought.
So did I order the wrong ones or is that just how they are?
Thanks
Stock Bulb.(top)
Garage 1217 wedge 194168 LED (below)
Thanks
Stock Bulb.(top)
The bulb for back up isn't a 194 that's way to small its side marker and license plate bulb size. If you have the option TYC tails its diff than the stock tails.
These are probably the brightest bulb you can get for reverse bulbs. There is actually a Gen1 in his pics for comparison make sure you get the correct bulb.
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
Stock tails = 7440's
TYC's = 3156's
TYC's = 3156's
So from what your saying, I did get the wrong bulbs. I even emailed Garage1217 before I ordered and asked specifically for Reverse LED lights for a 2006 Scion xB and their reply was;
"For the reverse lights, the brightest I have are located here.
http://store.garage1217.com/insane-194168-wedg194168.html"
Ive already emailed them just to double check. Still waiting for a response.
____
____
Yeah he might have copied the wrong link or thought you meant license plate lights here is an industry guide for bulbs just follow the drop downs. What I posted is correct I have had both TYC's and stock tails. the guide only lists stock items it wont show option lights
http://www.sylvania.com/ConsumerProd...lacementGuide/
http://store.garage1217.com/insane-1...edg194168.html ( he does not carry any bulbs large enough for back-ups.)
look at the description from the link you posted it says exactly what it is
"ALUMINUM RINGED WICKED 194/168 WEDGE BULB! BEST BULB FOR DOME LIGHTS AND LICENCE PLATE LIGHTS! GET THAT LEXUS LOOK! INSANE BRIGHT! ------ALL COLORS BACK IN STOCK / ALL BACK ORDERS HAVE SHIPPED!-----"
Thanks for the help.
these are the brightest
put the ones you bought in the rear license plate bulbs they are good for the price
no like the wiriing. because the vents lead to pipes that go deep in the bay area. so did u drill through that piping?
______________________________
LED Fluorescent
led ceiling lights
led strip
LED Fluorescent
led ceiling lights
led strip
OK, I just want to know if I gotthe wrong LEDs. I have a 06 xB and I wanted to upgrade the stock bulbs for the reverse lights to something brighter. My back window is tinted and I have trouble seeing at night when I'm backing up. I ordered a set or Pure white LEDs from Garage 1217 and the connector didn't seem to fit well. I had to bend the leads in the socket to get the LED to fit and it still was loose. Also, it wasn't as bright as I thought. So did I order the wrong ones or is that just how they are? Thanks
Stock Bulb.(top)
Stock Bulb.(top)
These are the ones you need bro, I bought wrong ones too at first, Good Luck!
____
Mine are 7440 wedge.........much brighter LED ones now. Did brake/tail bulbs too, also wedge, 7443 red strobe LEDs. Fogs 9006 LEDs. Headlights H4 LEDs. Dome 3175 LED. License plate LED panel pods. 3rd brake light 2nd gen LED mod, climate control 2 T4 neo wedge LEDs.
