Hatch doesn't open, No Power back there
Old 03-04-2018, 12:18 AM
crispins's Avatar
Default Hatch doesn't open, No Power back there
I am getting a 2006 xB all fixed up.
It was missing the tailgate garish when I got it including the lic plate lights and the button to pop the hatch open.
I have the hatch open and have probed all the wires and do not see positive anywhere.
Which wire should have power and if I have no power where should I look?
Plans are to add a new button under the garish once I get it figured out.
______________________________
Last edited by MR_LUV; 08-30-2018 at 12:45 AM. Reason: Moved to Correct Forum by Administrator
crispins is offline
Old 03-04-2018, 01:13 AM
Administrator
Administrator
MR_LUV's Avatar
Originally Posted by crispins
I am getting a 2006 xB all fixed up. It was missing the tailgate garish when I got it including the lic plate lights and the button to pop the hatch open. I have the hatch open and have probed all the wires and do not see positive anywhere.
Which wire should have power and if I have no power where should I look? Plans are to add a new button under the garish once I get it figured out.
MR_LUV
MR_LUV is offline
Old 03-04-2018, 01:48 AM
crispins's Avatar
Originally Posted by MR_LUV
MR_LUV
Thank you but that is not the info I need.
looking for wire diagram for the wires inside the hatch.
I do not see power anywhere in there, I know at least one wire should have power there.
crispins is offline
Old 03-05-2018, 01:47 AM
crispins's Avatar
So if I am not getting any power to the hatch door on any wire except for the wire that powers the lic plate lights then what should I do?
Is it a constant 12 volt back there or does it turn on and off based on if the doors are locked or not?
crispins is offline
Old 03-24-2018, 12:33 PM
RichBinAZ's Avatar
This seems to be logically correct, but I don't know how it is done - i.e. does the lock circuit interrupt the power or the ground.
So there is no wire to the lock that you can find? I take it you have the back cover off... any sign of a wire going from the door into the body?
RichBinAZ is offline
bmxtc
Scion tC 1G ICE & Interior
04-23-2019 09:50 PM
cyberiad
10-05-2013 06:20 PM
Cabana
Scion tC 1G Wheel & Tire
07-30-2011 05:58 PM
chowee21
02-01-2011 05:27 PM
Twilight2ner
14
06-07-2010 05:22 AM
Quick Reply: Hatch doesn't open, No Power back there
