Rear Washerfluid
Bought an 05 and there was no rear washer fluid pump. Bought one and installed it but almost nothing comes out. If i hold it down for 5 seconds a little dribble will come down. I assume it's clogged. Anyway to fix it? if it is even worth it?
yup.remove it
Unfortunately, it does not actually spray out, when u push the washer spray for the rear:icon_redface: You should see a slow small steady gravity flow :frown:,
Ya mine is more like one small drop after a good 5 second wait....I'm not sure it's supposed to be that slow and that small amount of fluid
How does the nozzle look? Id also try to blow out the spray tube with canned air or even replace the hose if thats the culprit....enjoy taking the trim apart though.
