xB 1st Gen Tail Lights issue..
Hi everyone!
I have an 05 Box that just got involved in a hit run last week. She was popped pretty good on the passenger side fender. So the fender will be replaced as well as that headlight. All that said, now the tail lights aren't working as well as the interior lights. I changed the bulbs in the tail, checked the fuses under the dash and nothing. Can't figure it out. The brake lights are still working however along with the turn signal. The turn signal is flashing pretty fast due to the busted headlight. I'm stumped. If anyone can help it would be greatly appreciated! *Moved to Correct Forum by Administrator Sticky Where to Post Your Question Sticky How To Advanced Search SL (Scion Life) ______________________________ |
When you say, "now the tail lights aren't working as well as the interior lights," what exactly do you mean? Brake and turn signal are working, outside of the fast flashing, so what isn't working or working as well?
check fuses?
The tail lights, dash lights (except clock), side markers and front parking lights are all wired on the same 10 amp circuit. The BRAKE lights, turn signals, head lights and fog lights are on separate circuits. I currently have the same issue; i.e. tail lights, front parking lights, license plate lights and dash lights are in operative. The fuse is fine (replaced it any way), replaced the headlight/turn signal switch, still not working. Looking for a relay somewhere but wiring diagrams are not my strong suit.
