Blew parking lights fuse, which one is it? ( I GOT IT!!!)
Parking lights, speedo light, tail lights all not working. I know I know, I'm dumb and had the switch on.
I am in the middle of adding some lights to the cup holders and I was testing to see which wire from the auto shifter light wire was + and - and blew the fuse(s). Since it the on/off switch is for inside and outside lights, would there be 2 fuses I need to swap out? :ponder: I wanna hook these bad boys up and be done with this! Thanks everyone. Okay I figured out which one it is. :rolleyes: |
kudos to you zman, maybe post your findings to help out others?
It's the 10AMP fuse in the fusebox that says "TAIL"
It's for all the parking lights and interior ones. I took the one for Hazard lights and moved it to TAILs. |
This is a general warning to all those who are non-believers. Never let the blinker fluid run low. The perilous dangers of such actions could result in changing a fuse. GASP!
Glad you found it mangs. |
Originally Posted by spr0k3t
(Post 3601774)
