my scion makes a weird noise at high speeds
Old Feb 11, 2009 | 12:51 AM
drivexB's Avatar
Default my scion makes a weird noise at high speeds
it sounds kind of like "womph womph womph"
is this normal? or could it be the rotors (the sound seems to be coming from the rear)
Old Feb 11, 2009 | 02:14 AM
tanakasan's Avatar
High speed...how fast? Wind noise? Check your tires. Pressure, nails, cuts.
Not the rotors if it sounds like coming from the rear! Drum brakes back there!
G/L!
Robert
Old Feb 11, 2009 | 03:19 AM
drivexB's Avatar
G/L!
Robert
60km and up
so city driving speed
tires are okay
i had one almost flat in the front but i fixed that
i told my mom about it and she said wheel bearings
i dont know
ill just take it into my mechanic
Old Feb 11, 2009 | 05:13 PM
MadMike550's Avatar
how many miles are on yours?
Old Feb 11, 2009 | 10:31 PM
drivexB's Avatar
54,000
Old Feb 12, 2009 | 01:46 AM
tanakasan's Avatar
Good point!
I remember a post or two about xB rear wheel bearing issues here. G/L with it!
Robert
Old Feb 12, 2009 | 11:43 AM
2Black2Box's Avatar
This may be a "dumb" question but... are your back windows down while driving high speeds? I know some people don't like the wind in their face so they let their back windows down. Being in a box (and most other cars), there will be a "helicopter" sound coming from the rear if your rear windows are down and your front windows are not.
Old Feb 12, 2009 | 12:59 PM
MadMike550's Avatar
54K?
I suppose it's possible it could be a wheel bearing...
no bent rims or unusual tire wear is there?
Old Feb 12, 2009 | 07:24 PM
drivexB's Avatar
54K?
windows are always up lol
and rims are fine, and the tires look normal
Old Feb 12, 2009 | 08:13 PM
MadMike550's Avatar
sometimes tires can break a belt..and look normal...
not sure if thats your problem..but it can happen
Old Feb 12, 2009 | 08:26 PM
CBSIMONSEZ's Avatar
If it were a tire failure he would feel it as well as hear it. Esp. at 60MPH.
I too would first suggest that your windows were down and you were getting reverb from the wind rushing in.
If not, then raise the rear of your box and take a look underneath. Everything down there should look in its place. There really isnt a lot udner there to begin with.
You may want to take a look at your tail if you have one.
take a look at your rear window wiper as well. It should be snug against the back glass.
Also, now that i think about it .. make sure your rear lip is bolted together in the center and all along the upper edge.
Old Feb 12, 2009 | 09:35 PM
drivexB's Avatar
ill look at all this right now
Old Feb 13, 2009 | 03:50 AM
shortbus_8's Avatar
slow down
Old Feb 13, 2009 | 04:06 AM
tanakasan's Avatar
>>Tire issues?<<
Old Feb 13, 2009 | 05:27 AM
Sciond's Avatar
yep
Old Feb 13, 2009 | 07:26 AM
bB2NER's Avatar
Music City Scions
Def. weel bearing problem. Check both and replace the bad one.
Old Feb 13, 2009 | 06:21 PM
Clokwerck's Avatar
Def sounds like a wheel bearing, I just replaced one of mine at 37K ugh.
Old Feb 14, 2009 | 07:56 PM
drivexB's Avatar
Originally Posted by shortbus_8
slow down
on the highway?
no thank you
and when i said 60 i meant your 40 because im canadian and we use metric
so yeah, i hear the noise pretty bad at 40
Old Feb 14, 2009 | 08:28 PM
CBSIMONSEZ's Avatar
slow down
on the highway?
no thank you
40 MPH ... even a tire that had a belt shift would make noise at that speed. But im sure if a bearing was bad that it could. Me personally, i havent had any expierence with a bad bearing so i wouldnt know. At 40 MPH i dont think that a loose rear lip would move enough to make any noise.
Old Feb 14, 2009 | 11:53 PM
drivexB's Avatar
slow down
on the highway?
no thank you
ill take it in and get it checked out
