my XB wont start!!!!!!!!!!!!!!
today i went over to the lot only to find out it wont start -_-... the battery is fine ( i have 3) the terminal in the front battery is a lil rusty but voltage is above 12.7 .. i checked the starter fuse aswell as the am2 fuse its not burned
next i took out the starter relay and made a jumper (short) between terminal 3 and 5 ... and still nothing .... should i switch the starter???? starter selonoid ???? |
is it trying to turn over?
Any clicking noises when the key is turned?
Originally Posted by unicxb
(Post 4155614)
Originally Posted by FlintMica17
(Post 4155618)
Most times when the starter solenoid is at fault you will hear a single click sound when turning the key. If you are hearing nothing i would begin to look at power and ground, or possible security system issue. Speaking of, do you have aftermarket security installed?
[QUOTE=FlintMica17;4155637]Most times when the starter solenoid is at fault you will hear a single click sound when turning the key. If you are hearing nothing i would begin to look at power and ground, or possible security system issue. Speaking of, do you have aftermarket security installed?[/QUOTE
i do hear a click , but it sounds like a relay making contact , sounds like a spark going on , but i hear that when i put the key in acc |
