Thinking of getting OTG camber shims
Will it be ok to use these as an everyday driver?
yup. chek them out on my 501's
https://i19.tinypic.com/62n7oqv.jpg no abnormal tire wear or anything like that yet. they looks loads better and once i drop it with some fender flares. it will look really good! had them on for over 40K i think |
You shouldn't have a problem. I have them on my box.
I can't tell the difference? whats the point?
^^^ those peeps have the spacers shims, i want the camber one's.
the spacer one's just get the front wheels and the rear wheels flush. the camber shims, tilt your wheels at the top |
i thought so, For better traction in turns....tehehe
does anybody know whats the part number on those camber shims? and wheres the best place to buy (best price)? im in the middle of redoing my suspension
my ideal sport suspension includes: megan springs - check megan strut bar - check megan h brace - will order 1st of august kyb gr-2 shocks and struts - will hopefully order 1st of august camber bolts - will order 1st of august rear camber shims - will order 1st of august poly endlinks - check poly sway bar bushings - check now for power : intake - check nytrex 30 shot dry kit - will order 1st october brakes: cross drilled/slotted rotors - will order 1st of october performance pads - ? stainless steel brake lines - will order 1st of october |
my ideal sport suspension includes: megan springs - check megan strut bar - check megan h brace - will order 1st of august kyb gr-2 shocks and struts - will hopefully order 1st of august camber bolts - will order 1st of august rear camber shims - will order 1st of august poly endlinks - check poly sway bar bushings - check now for power : intake - check nytrex 30 shot dry kit - will order 1st october brakes: cross drilled/slotted rotors - will order 1st of october performance pads - ? stainless steel brake lines - will order 1st of october there's no part number, ^ thats the only place I know that sells them |
wow onetongarage.com's price is a little on the high side but i have to say the quality looks top notch - hhhmmm.....
now the true question is : lets say you had to pick one thing or the other camber shim kit or put the money towards some sticky tires what would you go for? i imagine that the sticker tires would make a bigger difference per formance wise huh? well il probably end up getting both - shims first that way i knock out the suspension in one tear down - damn i hate my scion xb and then again i love it , then i hate it cuz i cant stop modding it , then i love it cuz it makes me happy DAMN YOU SCION !!! |
