vcs & trac off light but no eng light
My vsc & trac off light came on when i hooked up an afrter market tach. I keep seeing this thing about a EFI fuse but don't know where it is located i looked in both fuse panels and see nothin marked EFI if anyone knows were this is ?
Trak/vsc call out to fuse AM2 15 amp. This fuse is number 7 in the owners manual fuse box diagram on page 222 and is called out there as starter, srs airbag, Fuel injection etc. This fuse box is located in the engine compartment next to the battery. If it isn't blown you could simply remove and check every fuse in the car, there aren't that many between the under dash box and the eng compartment box, and are easily visually verified. Good luck
Yes i tried pushing the trac off button and the tach was removed the next day .I think when i was hookin up the tach i set it off . i wasn't sure wihich wire to hook it to so i hooked the pos and ground up and then took the green wire and touched it to the plug one spot at a time and noticed the light was on so i am not sure ?
If you're confused about the wiring, go to https://www.scionlife.com/forums/viewtopic.php?t=138456 and download the xB diagram. Then find the Traction Control section and veryfy that you correctly hooked up all your wires.
vcr trak off check engine fixed on XB
No. 12 fuse. Pull wait a minute and bam! Gone. 79k mi. On car. Drove home...still good. In fact, runs better! A GENIUS here suggested it...Cannot thank him enough. In fact I had to join just to thank him.Be well
SkillFreeJake
Scion tC 2G Aero & Exterior
07-27-2015 12:34 AM
