xB door lock motor malfunction
Old Feb 4, 2009 | 06:59 PM
TypeX's Avatar
Originally Posted by George
Originally Posted by TypeX
Find a scionlifer in your area
Swap parts and have him bring it in for service
Voila
You consume more in time and hassle than you gain in parts.
It was a joke hence the little smiley laughing guy....
Old Feb 5, 2011 | 08:24 PM
NYCxB's Avatar
Looks like my driver side died today. All the other locks unlock from the fob, but the driver side will not engage to lock or unlock. Any thoughts on how to fix this? Thanks as always!
Old Feb 6, 2011 | 03:52 AM
frogbox's Avatar
Use the key , or buy part number 69120-52030 Actuator assembly.
$127 or there abouts.
Old Feb 6, 2011 | 02:34 PM
NYCxB's Avatar
Is this a difficult diy install?
Found it for roughly $85 here:
http://www.toyotapartszone.com/oem/t...120-52030.html
Old Feb 6, 2011 | 07:36 PM
frogbox's Avatar
Easy install, remove inner door panel , reach instide undo 2 small screws , disconnect electrical connector , install electrcal connector , place actuator inplace, reinstall 2 screws , reinstall inner door panel. Done , now your key fob and alarm will work correctly.
And for the price , don't forget to add S&H , would still bring it to over 100 bucks.
Old Feb 6, 2011 | 07:50 PM
NYCxB's Avatar
The other locks work just fine, so hoping this replacement will end this. Is there anything else that could cause this?
Old Feb 17, 2011 | 07:01 AM
kewlbox's Avatar
Cold weather. when mines ourside and the temp is upper 20's or lower the drivers door will not fully unlock. when it's warmer it works great.
Not sure why but i'm thinking they used a heavier grease on the door that gets used more?
Old Feb 17, 2011 | 09:05 PM
NYCxB's Avatar
Received the part today. Do I need to grease this thing at all? Also do I need to disconnect the battery before I install?
Thanks again all!
Old Feb 18, 2011 | 02:11 AM
frogbox's Avatar
Thanks again all!
Use a little boot/dielectric grease on the connector , and I always disconnect the battery for electrical work. Ever have jumper cables touch as you remove them from you car? accidental fireworks are not fun.
Old Feb 18, 2011 | 03:56 AM
NYCxB's Avatar
Because I am a dope, put that on the prongs of this piece?
wonderworm
Nov 19, 2023 01:44 AM
Inazuma
20
May 3, 2023 01:58 AM
DaBlackBox
134
Apr 10, 2022 02:04 PM
toyotaisme
Jan 10, 2015 10:24 PM
lunchbx05
Dec 29, 2014 07:53 PM
