Antenna broke..Now What?
So my roof antenna broke. Can't just screw in another antenna as it seems to be damaged in the seat of the mast.
Looking for a not fancy replacement and a video on how to replace it. I believe I need to go thru the ceiling panel...ugh. help. *Moved to Correct Forum by Administrator Sticky Where to Post Your Question Sticky How To Advanced Search SL (Scion Life) ______________________________ |
I would imagine you could pull down the rear of the headliner enough to gain access to the antenna without removing the liner entirely.
Probably have to pull the c pillar panels out at the top, at least. Maybe the remove grab handles, some weatherstrip, etc. Basically you're going to have to remove enough plastic trim to allow you to drop the rear portion of the headliner enough to access the antenna. One of those jobs that isn't really difficult, but is tedious. Take care not to crease the headliner permanently. You won't have to do all these steps, but in this thread is a summary of removing everything to get the headliner out. https://www.scionlife.com/forums/sci...dliner-159859/ |
