vent visor removal
I bought my 2012 XB slightly used and unfortunately, it has some ugly vent/ window visors on it that fit inside the window channels but are also glued fast with that double sided sticky tape/foam. Is there a way to remove that stuff without damaging the window seals? I really wanted to go with the seamless style visors. Also, who ever had it before me also stuck some cheap convex mirrors on the side mirrors and put them in a bad spot on both mirrors. How can I removed them without damaging the factory mirror glass? They seem to be stuck fast with the same stuff the window visors use. Thanks.
Heat gun to the mirrors. Really low though.
/\ yup.. get a heat gun / blow dryer, and warm up the glued/taped parts and slowly pull those bad boys off. goo gone from ur local autozone or something to get rid of the residue
Originally Posted by jacobxahn
(Post 4030162)
Thanks guys, I wasn't quite sure what to use to get the stuff off without causing damage. I didn't even give a heat gun any thought. The vent visors I can live with for a little bit yet, but the convex mirrors have got to go.
I do think its a fairly "simple" act if you were to remove your vent visors without doing any unnecessary damage to your car. You should start first by looking for any DIY video out there like "weathertech vent visor installation". Simply do steps, in a reverse manner and there you have it.
Originally Posted by afoulk
(Post 4030137)
by the way, replace those fixed convex cheap mirrors it with MAXI-VIEW mirrors...had it since '06...the best ! really..the best...you install it on the upper/inner corners of your side mirrors---and you CAN adjust its position to your liking!...not cheap at $15/ea when I bought it back then, but worth it so much in convenience!
REDACTED
