2008 Scion xB broke down..
The serpentine belt broke when driving down the highway. I put a new one one. Car want start up. The camshaft is spinning , but nothin!!
I hooked my computer device to it. And here are the codes it gave me. Fault log report generated by Torque for Android ================================================= Vehicle VIN: JTLKE50EX81036193 Vehicle Manufacturer: Unknown Vehicle Calibration ID: 31248000 Current Fault Log ------------------ P0117: Engine Coolant Temperature Circuit Low Input P0351: Ignition Coil "A" Primary/Secondary Circuit P0352: Ignition Coil "B" Primary/Secondary Circuit P0353: Ignition Coil "C" Primary/Secondary Circuit Pending Fault Log ------------------ P0327: Knock Sensor 1 Circuit Low Input (Bank 1 or Single Sensor) P0354: Ignition Coil "D" Primary/Secondary Circuit Historic Fault Log ----------------- ECU reports no historic faults Other discovered fault codes (possibly pending, current or manufacturer specific Any Suggestions to what the problem could be ?? Thanks. ______ |
Inspect all sensors in or around the belt path. Look for visual damage to wire harnesses and or sensors themselves. Before disconnecting/reconnecting anything electrical, you might want to disconnect the negative battery terminal and wait 90 seconds.
A bad camshaft position sensor and or bad crankshaft position sensor can create a no spark condition. I don't know if the same applies to your coolant temp and knock sensors. |
Originally Posted by 62Fender
(Post 4293092)
I just preemptively changed the belt on my xB. It's 10 years old with only 52K miles on the clock. The belt looked good, but I thought it was time.
I wonder what are the age and miles on the OP's car? I also changed the coolant and the larger hoses just for safety. __________________ |
