Help! Low Idle RPM after changing battery
Old 07-11-2012, 03:12 AM
gslape's Avatar
Default Help! Low Idle RPM after changing battery
I have an 2008 xB Automatic with 89k miles. Car has always been running great. I had a bad battery and replaced it. Ever since then the car has low idle. The car runs great once you give it throttle but at idle its too slow so it is rough. Any ideas??
gslape is offline
Old 07-11-2012, 04:17 AM
Jon
Moderator
Moderator
Jon's Avatar
Disconnecting the battery resets the ECU. It should go back to normal after a few days/trips.
Jon is offline
Old 07-11-2012, 04:55 AM
Wagonistas
phatchef's Avatar
start your xb then let it idle for a few min and it should be good to go again
phatchef is offline
Old 07-11-2012, 02:24 PM
my06tc's Avatar
after changing battery,the computer resets itself,let it idle for 10 mins or so,disconnect it again,
my06tc is offline
Old 07-12-2012, 12:11 AM
jetas's Avatar
its relearning itself. ECU was reset. Just drive it. kick on the AC too.
jetas is offline
mrsocks
01-20-2015 01:29 PM
Bakoscion46x
01-19-2015 02:39 AM
cid_mcdp
01-05-2015 02:45 PM
TheTripleC
01-04-2015 06:46 PM
eric_m
79
03-17-2013 12:21 AM
Quick Reply: Help! Low Idle RPM after changing battery
