Inside fuse box location for 2008 xB?
Does anyone know where the fuse box is located on the inside of the 2008 xB? I found the one under the hood, but I need to get to the one inside.
Theres two on our xbs, one under the hood like you found. The other is located underneath the steering wheel. Below your mirror controls on the left hand side. You have the remove the panel there. It should nap in and out. Your gona have to get under there and look up. You wont see it unless you do. Good luck!
It's small, only about 15-20 fuses located near the hood latch release facing the floor mat, what'd you blow? lol
Fyi, stock fuses are the ATM lo-profile fuses, you can still use the standard atm fuses though |
Fuse
I blew the power outlet. I have a power converter running on it and I guess it is pulling to much power and blew the fuse!
