P0301 code
P0301 code
I have been trying to get this code to go away. My VSC Light off blinks and Check Engine Light will also blinks. I finally got this code. I have swapped coil packs from 1 to 2. And I have replaced all 4 plugs with new NFL. There was a bunch of gunk on Cyl 1 plug.
All four were whitish. I have 193k miles. It uses oil quite a bit between oil changes. I also dumped a bottle of Seafoam in the tank at a half tank and let it run for about a hour. Hoping it would help clean out the injectors. I'm dreading buying a new injector
because they run $137. It will hesitate when giving throttle some times. But at idle and light throttle it's smooth. Help.
Last edited by MR_LUV; 05-26-2018 at 01:46 PM. Reason: Moved to Correct Forum by Moderator
You've tested the usual stuff. Next step is injectors. Maybe try swapping 1 & 2 to see if it moves. Also did you clear the ECU after you swapped the coils to make sure it was reading a new code?
