PCV Valve Location
Guys,
Can you point me to the PCV location on this car? Thanks. |
You ever find out where the PCV valve is located? Thinking of replacing mine.
The PCV valve is threaded into the left rear of the valve cover. You can replace it or simply clean the old one.
Edit: Since I removed mine today to swap it to the new valve cover I thought I'd mention that you need a 22mm wrench to remove the PCV valve. Also, although I have a new PCV valve I re-used the original since a shot of WD40 cleaned it to like-new condition. |
