Save my a$
Vehicle 2012 Scion xB 2.4L manual. replacing clutch and flywheel, cracked my secondary or upper oil pan in the process just need to know if I can just buy and install
or do I have to go through the complicated process of basically rebuilding an engine? No access to all data or other similar items. *Moved to Correct Forum by Administrator Sticky Where to Post Your Question ______________________________ |
You should be able to just replace. It contains the balance shafts and oil pump and such but it is separate and below the crank assembly.
