Soo I deleted it...
4 Attachment(s)
I bolted on the DC Sports Axle Back and then took it to my local custom shop that a buddy of mine works at and had a Thrush glass pack welded in. On the gas it's a little loud but at speed it's not bad. Not raspy or hondaesque...:biggrin:
I noticed a 600rpm drop at speed (62mph) instead of cruising at 3100RPM I cruise at 2500rpm...created some flow there. Just the axle back netted me 1.8 mpgs so I'm curious to see if I get a few more...almost to 36 mpgs here are some pictures & a crappy video: Attachment 34905 Attachment 34906 http://i293.photobucket.com/albums/m...79d7e6c392.jpg Attachment 34907 The tumor removed! Attachment 34908 |
RPM has nothing to do with exhaust flow, or any other motor modification.
62mph at3,000 RPMs with always be 62MPH at 3000 RPMs unless you are swapping gears or a final drive in the transmission. |
It's simply an observation that the engine is working less to maintain speed....
Placebo, trust me.
So why am I 600rpm less at speed now?
Did you change anything in the transmission?
If the answer is no then it isnt. Just think about it, and think logically about how gears (even the ones not in cars) work. Even though less force may be required to move them now, they will still move at the same speed in conjunction with each other unless one of them is altered. |
Nope just scuba delete and axle back...
so then your RPM is the same as it was prior to any modification.
It's not though...I am at speed on the same route 600 rpm less...
Ok, if you say so. But google it, and know that what youre trying to convince me of is impossible.
I'm not arguing just making the observation...
Originally Posted by TheQuietThings
(Post 4048091)
Originally Posted by AnotherDude
(Post 4048141)
x2. Your RPMs shouldn't change at all. If it really is down, you need to get it looked at.
Originally Posted by elsenordave
(Post 4048154)
it's a by product of the engine not having to work as hard since I took the restrictive elements out...:wink:
Just so you understand mate. ITs dope that you had that done and im sure the car is performing better. However your RPM rates will never change because of a flow. I have header/intake/2.5 exhaust cat back. n some other things. My rpm wont change. RPM is solely based on gearing.
this might be a dumb question, but will it pass smog like this?
I understand what y'all are saying but I'm just giving my observation...I could care less @criminaltc what you think, be as adamant as you want, I made a simple observation and was sharing it. I have nothing to gain here...
i changed my oil and my rpm's is at 1800 at 65 mph
Originally Posted by 2011xb4me
(Post 4048202)
No smog in Hawaii, but there is recon and safety check.
